It is currently Dec Sun 05, 2021 5:38 pm
 Post subject: National NC-270!
PostPosted: Sep Wed 15, 2021 10:03 pm
With matching speaker.
What a gorgeous radio, in Cosmic Blue!
The radio stirred some controversy here...
viewtopic.php?t=91498
Description -
"National NC-270 Ham Radio Receiver. IN pretty good ship, no scratches, all functions work, built in calabrator, changed 5Y3 to solid state rectifer to lessen heat, sprayed controls, manual included, works ok, like all vintage equipment could use a tuneup! chassis is clean, paint ok also"
Judging from the ARF thread, alignment can be tricky, but not impossible, but is vital for performance.
Did I misread, or does this want a 72 ohm unbalanced antenna? Can someone enlighten me?
I deaerve to be flogged with a Transoceanic whip for buying this, but what a beautiful piece!
"Invisible airwaves crackle with life
Bright antenna bristle with the energy"
 Post subject: Re: National NC-270!
PostPosted: Sep Thu 16, 2021 1:07 am
I have one along with some of the other cosmic blue National receivers.
It is like other radios of that era and type, you do NOT need an exact antenna match for it to work OK. Practical antennas will present a complex impedance that varies widely across the operating range. If you want a perfect match, get a dummy load :)
I have seen the articles on the work some people have done with the 230 khz. inductors in these National radios. Maybe I am lucky but I have never had an issue with the IF strip alignment in these. My biggest criticism of these is they aren't as mechanically robust as some of the older and/or more expensive National sets. They work fine but the build and operation doesn't have the feel of a HRO, NC-183, NC-300, etc.
Rodger WQ9E
PostPosted: Sep Thu 16, 2021 1:42 am
Rodger WQ9E
"If you want a perfect match, get a dummy load :)"
ROTF
A few complain that this and similar sets are weak receive on 10 and 6 meters.
Could it be this is because they are using antennas optimal for HF?
I'm going to experiment! :D
PostPosted: Sep Thu 16, 2021 7:19 am
I can never figure out the propensity towards introducing "sand" in tube equipment. Why is it considered a worthwhile improvement replacing a common full wave rectifier tube, like a 5Y3/5Y4 or a 5U4 with solid state rectifiers? I've seen this advocated with a National NC-183D as well, supposedly to reduce heat inside the cabinet, and transformer. But given the fact the the transformer is heat sinked by being bolted to the chassis, the cabinet is spacious and extremely well ventilated, the mod seems rather fruitless. They even include dropping resistors to keep the plate voltage from going too high, which sort of defeats the aspired goal.
If the intent was to boost the B+ voltage, for enhancing performance, well maybe? If the tubes were rare, expensive, or failed easily, certainly! I have a feeling that there are some people that just have to mod things for the sake of claiming they improved something, even though there is nothing really to be improved, the set was designed to operate at a certain temperature, in a given voltage range. If preserving the transformer is the goal, well the ones in the NC-183Ds didn't fail because of having a tube rectifier, they failed from the pair of bypass caps, between each leg of the H.V winding to ground, shorting out, replace them with safety caps or clip them out. Also I have never had a directly heated rectifier tube fail by shorting out, but silicon rectifier diodes do.
Regards
Arran
PostPosted: Sep Thu 16, 2021 10:10 am
Dalton, in case you have not seen these notes:
https://people.ohio.edu/postr/bapix/NC270.htm
There is mention of the power transformer getting very hot, suggesting a reduction in line voltage would be a good idea. I think it's a good idea in general, line voltage today being higher than it was in 1960.
The QST reviewer (Jan 1961) thought highly of the NC-270's 6 meter sensitivity. Which suggests your receiver on 10 and 6 may not be performing up to its original level. Or perhaps that the reviewer was not hard to impress.
Something I thought interesting in the design: V6, a 6BA6, is referred to as a pentode product detector. Yet it looks to me to be an ordinary IF amp stage, with the BFO coupled to its control grid through a small cap. I believe that used to be called 'enhanced BFO injection' back then. The heterodyned CW/SSB signal still ends up going through the AM detector diode. The later economy version NC-155 used a separate product detector, the output sent to the audio stages. Not a criticism, btw, just a detail I found interesting.
Rob
PostPosted: Sep Thu 16, 2021 4:34 pm
Regards
Arran
I jnow what you mean. I have 2 183D's, one of which has a toasted transformer.
PostPosted: Sep Thu 16, 2021 4:39 pm
Rob
Thanks, Rob!
I do have a variac, so I will run this set at lower voltage, which hopefully will extend it's life.
Thanks for the notes and other information.
PostPosted: Sep Fri 17, 2021 2:42 am
I would try running the transformer with the tubes pulled, if it still gets warn it may have a short in the H.V secondary, or the heater wiring.
Regards
Arran
PostPosted: Sep Fri 17, 2021 3:19 am
Not 'enhanced' BFO injection, 'exalted'. Exalted BFO injection sounds much better.
PostPosted: Sep Fri 17, 2021 10:06 pm
Regards
Arran
Thanks, Arran.
PostPosted: Sep Fri 17, 2021 10:07 pm
It does have a ring to it! :lol:
PostPosted: Sep Sun 26, 2021 12:20 am
Rodger WQ9E
Well, I finally got the rig and speaker hooked up, and am listening to Vermont calling CQ on 40 meters! (AA1SU.)
My only gripe is that I'm not getting a lot of sound from the matching speaker. I'm probably just spoiled by my NC-183D, which I had driving a KLH bookshelf speaker, that would blow you out of the room.
I even tried reversing the speaker wire hookup, made no difference.
Could just be the age of the matching speaker.
Will try hooking another one up.
PostPosted: Sep Sun 26, 2021 4:50 pm
Dalton,
Nice looking receiver!
Reversing the leads on the speaker should have no effect on the audio.
Is it the correct speaker for the radio?
Has the speaker been replaced with a different one?
Have you checked the audio power tube (and the rest of the tubes?)?
Best of Luck,
-Tom
PostPosted: Sep Mon 27, 2021 2:53 pm
Tom Herman wrote:
Dalton,
Best of Luck,
-Tom
Thanks, Tom!
I suspect that an incorrect speaker (ohms) was put in the matching cabinet. I will rectify this. (full pun intended.)
I set it up Saturday night, and the magic happened. From my notes on Sunday -
"Last night around 8:30, was listening to W6TA, Rancho Palos Verdes, CA. at 14.19 MC, SSB, on my 1960 NC-270. California to Erie on a 60 y.o. piece of gear, with 15 feet of wire for an antenna. Nerd heaven."
Post New Topic Post Reply  [ 14 posts ]  Moderator: Sandy
