It is currently Nov Sat 27, 2021 4:36 am
 Post subject: wards airline GEN1678A fm not working
PostPosted: Sep Thu 16, 2021 3:57 pm
my FM is broken on my Montgomery ward airline GEN1678A. but the am works perfectly i had recently changed the paper capacitors and was wondering why it does not work. And it did not work before I changed the paper caps. Plus I also swapped all of the tubes with known working ones. If anyone that owns a this one or a very similar one that knows how to fix this please let me know!
"And I Said Let It Make Some Sound"
 Post subject: Re: wards airline GEN1678A fm not working
PostPosted: Sep Thu 16, 2021 6:59 pm
Are the switch contacts for the FM broken?
PostPosted: Sep Fri 17, 2021 12:59 am
I tested continuity and all of them seem to be intact this model has a FM sub chassis maybe there is something wrong in there im not quite sure maybe the contacts are dirty
PostPosted: Sep Fri 17, 2021 1:04 am
but its weird because when i turn the switch the speaker pops and then sound disappears
PostPosted: Sep Fri 17, 2021 1:11 am
You do have a decent FM antenna (dipole) attached, right?
Possibilities beyond failed tube or cap: failed coil/transformer in the FM tuner, IF transformer, or discriminator circuits. These elements have no bearing on AM operation so a failure there would kill FM but allow AM to work fine.
Fault isolation may require the use of a signal generator and oscilloscope.
PostPosted: Sep Fri 17, 2021 2:58 am
i still have 4 electrolytic caps I got to change so I'm hoping that's the problem :mrgreen:
PostPosted: Oct Wed 13, 2021 5:20 pm
so changed the electrolytics and well still nothing but as I turn the switch the speaker makes a popping sound and then the radio goes dead but the tube still are conducting :? also i cracked the fm sub chassis open and nothing was bad so im wagering on a bad resistor or something -64
PostPosted: Oct Wed 13, 2021 5:28 pm
That still sounds like a bad connection somewhere. Check all your solder joints, including the tube sockets.
PostPosted: Oct Thu 14, 2021 4:02 pm
Will do I will check and update later
PostPosted: Oct Wed 20, 2021 2:40 pm
so i checked continuity and i still cannot find the issue this thing is kind of stumping me out! also i went over the main connections on the point to point terminals but still nothing. What else could possibly be wrong? also might i add i checked all of the tubes and there good.
PostPosted: Oct Thu 21, 2021 5:39 pm
the next thing im thinking that there is a off value resistor that is bleeding power off causing this undesired operation. So im going to check them all and see if any are bad. And then go from there i will check the tubes once again just to see if something is intermittent the switch appears fine. I will check the contacts again to see I may have missed something im not sure but this unit has a FM sub chassis and the "goodies" inside look good. The slug inside moves fine I just think its weird that the FM is broken but the AM works like its new. :(
Post New Topic Post Reply  [ 11 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: crtkecnkl659 and 34 guests
