It is currently Nov Mon 29, 2021 10:03 am
 Post subject: screen bias for the control grid of a 12sk7 tube?
PostPosted: Sep Sat 18, 2021 5:53 pm
I have been fighting this 12sk7 tube for several days, and have lost badly! I need help here: I have a 198 v power supply, and am using a 15K ohm resistor on the plate, and have 13.2 ma showing on the load line. My idle spot chosen shows 100 v , 9ma, and a grid bias voltage of -3 v. I will list my voltage and resistance values: My supply voltage reads 191 volts, My plate voltage reads 115 volts with the 15k ohm resistor. My screen, with a 56k ohm resistor, reads 112 volts, My control grid is grounded because that is the only way that I could get the control grid to be 191 volts { -3 volts} while the cathode, with a 470 ohm resistor, is 188 volts. According to my calculations, the tube is biased ok. But: If I place a 1 meg or even a 2 meg resistor on the control grid, the voltage there,186v, shows 2 volts lower than the voltage on the cathode,188v. You figure! Any input appreciated........................william
 Post subject: Re: screen bias for the control grid of a 12sk7 tube?
PostPosted: Sep Sun 19, 2021 1:04 am
How about a schematic with the voltages marked? A verbal description only leads to guesses for answers.
And what are you trying to do? Is this part of a radio or an experiment or what? Are you following some instruction or making it up?
If you are using the internet for information, be aware that many people posting there have no idea about what they are talking about.
PostPosted: Sep Mon 20, 2021 12:22 pm
I am confused by the title of your post. "Screen bias for the control grid..." Huh?
Then there is this: "My control grid is grounded because that is the only way that I could get the control grid to be 191 volts..." Shouldn't a grounded control grid be be zero?
Is this an amplifier, a receiver, an oscillator, or what?
Please post a schematic.
PostPosted: Sep Tue 21, 2021 5:29 pm
Thanks for the help everyone! I put in a 1 meg resistor on the control grid and put in a 15000 ohm resistor on the cathode, with a result of 6 volts on the control grid, which is perfect. Mission accomplished. Again. Thanks for the help!!!!!!!!!!!!!!!!!!!!!!
