It is currently Jan Mon 24, 2022 9:09 pm
 Post subject: ID this GE diode?
PostPosted: Sep Tue 21, 2021 7:59 am
50+ year old GE diode. Numbers on it are 337699 and 939. Need to find specs.
 Post subject: Re: ID this GE diode?
PostPosted: Sep Tue 21, 2021 12:41 pm
Why do you need to find the specs? If you can tell us what it came from, we can recommend a replacement. If you are trying to sell it, the postage will exceed its value.
PostPosted: Sep Tue 21, 2021 2:03 pm
That's probably a "house number" part made for a specific customer or purpose. Since they never released it to the trade as a standard part the specs on it are slim to none. But it is what was known as a "top hat" which was a line of silicon power rectifiers, standard recovery, typically low to moderate voltage, and low to modest current (under a few amperes anyway).
PostPosted: Sep Tue 21, 2021 5:14 pm
939 is probably a date code. This one is old enough that it could be the 39th week of 1959. The other number is a proprietary p/n.
Top hats were usually rated at less than an amp. If you need to replace it, use a 1N4007. If you want more margin, try a 1N5408.
I would not install that diode in any equipment that I valued.
PostPosted: Sep Tue 21, 2021 5:31 pm
Zener diodes also came in that package.......
-Chuck
PostPosted: Sep Tue 21, 2021 7:32 pm
And there was a recent thread about top hat diodes.
PostPosted: Sep Wed 22, 2021 4:31 am
I don't recall that GE ever made Zener diodes.
PostPosted: Sep Wed 22, 2021 10:14 pm
Neither. I have a box with dozens of old diodes and most are labeled 1N*** or if small, color coded rings. I know what the date codes are, but just wondered what the numbering on these meant.
PostPosted: Sep Wed 22, 2021 10:32 pm
When top hat diodes came up some months ago, we said that they were relatively low current despite the size, and probably aren't worth using. They think I threw mine out years ago, and I'm a real scrounger.
PostPosted: Sep Thu 23, 2021 12:18 am
The 1Nxxx number is the actual diode part number, and you can probably look them up by just pasting that number into Google. The rest are either house numbers, date codes etc ..
