It is currently Nov Mon 29, 2021 6:01 am
 Post subject: Toyota Tacoma HF Radio Power
PostPosted: Sep Mon 13, 2021 5:07 pm
Hello All
I want to use my 100 watt Alinco DX 70 in a field set up, powered by my 2021 Totyota Tacoma. I was wondering if I can power the radio (Transmit) using the power connector supplied for the trailer on the rear of the truck. Is that power connector supply enough amperage for the radio? I know it powers the trailer tail lights.
I was considering just using large alligator clips to connect directly to the car battery, but thought that the connector may be an easier source.
W2MDM
http://mikesradiosandstuff.weebly.com/index.html
 Post subject: Re: Toyota Tacoma HF Radio Power
PostPosted: Sep Mon 13, 2021 6:08 pm
A 100W radio can draw about 20 amps on transmit peaks. The usually procedure for radios of this power level is to connect cables directly to the battery, using a minimum of a #12 fused cable. I don't think the trailer wiring is sufficient for this type of power requirement.
Harvey, WA2AAE
Harv, WA2AAE
PostPosted: Sep Mon 13, 2021 6:27 pm
+1 The current draw is pretty substantial.
If you are running SSB, MFJ used to sell a capacitor bank that would handle the peak currents on voice peaks. Average current on SSB is pretty low, probably less than 10 Amps.
https://mfjenterprises.com/products/mfj-4403
I don't own one so can't comment on effectiveness.
PostPosted: Sep Mon 13, 2021 6:50 pm
I highly recommend to read this site https://www.k0bg.com/
i'm not sad i'm sober
PostPosted: Sep Mon 13, 2021 7:59 pm
Also check your manual. My F-150 has a chart of the locations where on the truck reduced power is suggested. In other words not all of the computers are in the same location.
The lucky ones realize the "Good Ole Days" while they are still in them!
AA5LP
PostPosted: Sep Tue 14, 2021 6:03 pm
A lot of good info there, thanks!
W2MDM
PostPosted: Sep Wed 15, 2021 4:33 am
I usually install a 40 amp circuit breaker on the trailer 12V supply wire on 7 pin connectors. Might check what the Toyota uses to protect that circuit in the tow connector. The ground and 12V feed are usually 12 gauge or sometimes even 10 gauge wires.
PostPosted: Sep Fri 17, 2021 3:32 am
Newer vehicles use the thinnest possible copper wires to save money. So check to see what gauge wiring you have going to the back, might not be up to the load.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Sep Fri 17, 2021 12:59 pm
I sure would not use the trailer wiring to run a 100 watt rig!
Todd
PostPosted: Sep Fri 17, 2021 7:12 pm
Thanks all for your ideas.
It is funny, but I have 2 120V outlets built in the truck bed rated at 400 watts. Thought about plugging in my Kenwood 12v power supply in one and running the radio from that!
12v DC to 120v AC back to 12v DC!
W2MDM
PostPosted: Sep Thu 23, 2021 4:25 pm
If your radio draws 20 amps on transmit peaks, you're drawing about 240 watts at 12VDC. The power supply is itself is going to eat up some power by itself. I think you'd be maxing out the system, let alone dealing with less-than-perfect sine waves in the process - - which can drastically reduce the resulting power. The radio was designed to operate on pure DC; anything less will introduce other issues IMHO. I'd just run a line to the battery and be done with it. 10AWG THHN wire would do the trick.
Dan
PostPosted: Sep Sat 25, 2021 1:34 am
Dan
That is what I am going to do, Dan. This way I am sure all will be ok, with a separate line, properly fused.
Thanks!
W2MDM
Post New Topic Post Reply  [ 12 posts ]  Moderator: Alan Voorhees
Users browsing this forum: Sal Brisindi and 23 guests
