Forums :: Web Resources :: Features :: Photo Gallery :: Vintage Radio Shows :: Archives
It is currently Mar Sun 26, 2023 9:21 am
 Post subject: What mode is this signal on 30 meters.
PostPosted: Aug Mon 08, 2022 2:15 am
I see this quite often. Does anyone recognize it's portrait?
AA5LP
 Post subject: Re: What mode is this signal on 30 meters.
PostPosted: Aug Mon 08, 2022 2:33 am
Possibly a Cuban "tapper" station. They have been actively jamming the 40 meter band. They may have expanded.
To keep a true perspective of one's importance, everyone should have a cat that will ignore them.​
PostPosted: Aug Mon 08, 2022 12:15 pm
The 10140 might be a harmonic of WTWW 5070 .
I don’t see any time indications. Was this at night?
PostPosted: Aug Mon 08, 2022 12:20 pm
10.130 MHz is the FT8 mode operating frequency.
PostPosted: Aug Mon 08, 2022 12:27 pm
MFSK ?
PostPosted: Aug Mon 08, 2022 1:56 pm
Might Be FT-4 digital signals. 10140 kHz is the FT-4 default. BTW, FT-8 uses 30_secobd timed intervals, have you listed to the frequency in USB mode? FT-4 uses 30 second intervals. and they are synced to within a 10th of a second or so.
PostPosted: Aug Mon 08, 2022 2:08 pm
That would be the gaps in the waterfall plot. Thanks Peter
Dennis, you might have decoding software in your extension dropdown
PostPosted: Aug Mon 08, 2022 2:49 pm
ft4 is 15 seconds, correction. you see similar at 14074 kc?
PostPosted: Aug Mon 08, 2022 3:59 pm
I think FT4 is 5 seconds and FT8 is 15 seconds?
PS: WSJTx software is easy to install. You need to have a computer-to-radio USB cable, however.
PostPosted: Aug Mon 08, 2022 4:17 pm
https://www.dxzone.com/ft4-frequencies/
PostPosted: Aug Mon 08, 2022 6:26 pm
Thanks guys. This was taken later on Sunday evening. I don't see it Monday. I think I'll load some software and see if I can decode it.
AA5LP
PostPosted: Aug Tue 09, 2022 10:35 am
It could be a USA amateur radio (digital mode) operator, but I doubt it. It doesn't look like a digital signal and 30m Voice is not allowed in the USA.
As far as amateur radio goes in the USA, we are secondary on 30 meters. "Fixed Services" are primary. It's hard to find much about those type of transmissions, because they are used by private, government, military entities and mostly outside the USA, for example NATO and some foreign embassies. Most Fixed Services are point-to-point.
I would think anything using 30m for that purpose is antiquated. Higher frequencies with digital encryption would be better suited these days.
PostPosted: Aug Tue 09, 2022 8:45 pm
FT8.
Post New Topic Post Reply  [ 13 posts ]  Moderator: Alan Voorhees
