It is currently Aug Mon 19, 2019 11:36 pm
Post New Topic Post Reply  [ 519 posts ]  Go to page 1, 2, 3, 4, 5 ... 26  Next
 Post subject: Got Collections? New Finds? Let's See 'em.....
PostPosted: Jun Fri 09, 2006 5:57 pm
Here's a spot to post pictures of your transistor portable radio collections and new finds.
PostPosted: Jun Fri 09, 2006 9:42 pm
Here is most of my collection. I excluded cheap 60s/70s multiband sets. I also have doubles triples and quadruples of many of these sets.
Left to right then center.
Sony CRF-5100 Earth Orbiter(late production) circa 1975-80 ten band
Norelco/Philips North American model L5W34T circa 1962 four band(FM BC)
SHARP Multiband FV-1710 six band circa appr 1968
Ray Jefferson model 630-RDF five band circa appr 1975
Next.....
Right to left
Zenith Royal 3000-1 Trans Oceanic ten band circa 1966(FM, no 13m band)
Zenith Royal 1000D Trans Oceanic ten band circa 1960(13m band, no FM)
Zenith D7000Y Trans Oceanic eleven band circa 1972-78(late production on mine)
Next.....
Left to right
Panasonic RF-5000A thirteen band circa 1968
Panasonic RF-2200 eight band circa 1975
Here we have some of the original paper work.....
Trans Oceanic 1000D
Next.....
Trans Oceanic D7000Y
Next.....
Sony ICF-5900W
Here are links to further paper work.....
http://antiqueradios.com/gallery/view_p ... ollection8
http://antiqueradios.com/gallery/view_p ... ollection9
All these sets perform beautifully. The Trans Oceanics have all been thoroughly cleaned and completely aligned starting with the IFs.
The only sets I haven't aligned because I see no reason are the Panasonic RF-2200 and Sony CRF-5100. All these sets are with 90% or better condition. I hate using the term "mint" because that infers they're the same as when new. I don't buy it with 20-40 year old sets.
Performance wise, these sets are very close to one another. The best is hardly above the worst in sensitivity. The main difference I find is image rejection and selectivity. Here they are in order with these parameters in mind.
Sensitivity/Selectivity & Image Rejection in order of best to worst;
Panasonic RF-2200 & Sony ICF-5900W(the 2200 & 5900W are the only dual conversion receivers in the bunch. Both operate about the same)
Sony CRF-5100
Zenith Trans Oceanic D7000Y & Panasonic RF-5000A(the Panasonic loses to the Zenith in image rejection, other than that they're equals in every way).
Zenith Royal 3000-1, Zenith Royal 1000D, Norelco/Philips L5W34T are just about equal in every way. If anything the 3000 T/O seems to have an ever so slight edge in SW reception. Being I have several sets each of the 1000D & 3000 it's an honest comparison. Not sure why but if you like to nit pick sensitivity, that's my finding.
SHARP FV-1710
Sound quality in order best to worst;Sound quality for the various sets are close. Some sound better on FM than others but not AM. This is based on overall sound performance.
Panasonic RF-5000A
Panasonic RF-2200
Zenith Trans oceanic models D7000Y & 3000(no real difference)
Zenith Trans Oceanic 1000D & Sony ICF-5900W(sound quality on FM is on par with the RF-2200. BCB/AM performance is about the same as the 1000D Zenith)
SHARP FV-1710
Build quality in order from best to worst
Now this is probably the most debatable category of them all. I've had all these sets apart at one time or another. Plus I have parts sets for all these radios so I feel I know them fairly well. All sets show generally good to excellent build quality given their intended use & price range when new. But, there are known issues with many to watch out for.
RF-5000A all T/Os SHARP FV-1710 and the CRF-5100 I would rate equal in build quality. The RF-2200, Norelco/Philips & ICF-5900W seem about the same in build quality. They are a step below the other sets.
The build problems associated with these sets are;
RF-5000A band button stops are rubber. They deteriorate with time causing loss of reception
Sony CRF-5100 have issues with the band scale drum warping, WATCH OUT FOR THIS! It's not always evident so if you purchase one ASK ABOUT THIS. You may find yourself disappointed. I've taken the time to contact Sony of Japan for replacements and they're not available. I also find many of the Epay sets seem to lack the original antenna. Note my pick is the original antenna for reference. Parts sets aren't common and when they do pop up on Epay they usually go for $70+ dollars.
Zenith 7000 series sets really have very few issues. Other than switch cleaning there are none to mention.
1000 & 3000 series sets suffer pitting and bubbling chrome. Also the brushed face cover pits badly. The carry handle is also the antenna and 5 out of 10 can be found cracked. Keep this in mind when shopping for one.
The Panasonic RF-2200 suffers dirty switches in a big way. I seem to find them needing a serious cleaning more so than the Zeniths. Also watch out for a broken rotating ferrite rod antenna. What breaks on these is the detent socket/ball that holds them up. Also ask about dial backlash. These sets use delicate plastic gears to rotate both the dial & dial scale/scroll. If the dial knob is damaged or turned past it's stop, damaged gears could be the result. This makes accurate tuning difficult.
Sony ICF-5900W. Similar to the RF-2200. Broken pop-up antenna, dirty switches. Also the battery cover seems to come up missing more often than not. If you are looking to purchase one, make sure you ask the seller. The dial system also suffers the same issues as the 2200, WATCH FOR THIS!
No known issues with the Norelco/Philips but I've been told the dial strings in most Norelco's are a Bear to deal with if broken. Worse than many of our beloved tube sets.
No noted issues with the SHARP sets. There are various models similar to the one I own.
Ease of use/Ergonomics
Operation is generally obvious, but I thought I would comment anyhow. My take on this is ease of use, handiness and portability in order from best to worst
1)Sony ICF-5900W - Very easy to handle, light, easy acquisition of operating controls. I've found I can get on freq FAST with this set. Easy to hold with one hand.
2)Panasonic RF-2200 & Norelco/Philips.
3)Sony ICF-5100 all Zenith T/Os & the SHARP - Easy to use but heavy making portability less desirable.
4)Panasonic RF-5000A - Damn heavy! I mean a serious 25 lbs of weight. Forget portability with this set. Also, slow to operate. Takes a second or two to figure out which band you're on and operate. Consider this monster set for permanent table top placement :?
Well that's all from me. I would like to see other multiband sets and any info associated with them from other members. Also any experiences counter to my own. Please post'em.
-Brian
PostPosted: Jun Sun 11, 2006 12:55 am
Great post Brian, I'll have to get busy and round up some sets for a shot.
PostPosted: Jun Sun 11, 2006 4:27 pm
I've posted 3 pictures of some of my collection to the gallery entitled "transistor collection 1, 2, 3. I haven't yet figured out how to post pictures into the Forum window.
(edit by moderator) Here they are!
PostPosted: Jun Sun 11, 2006 7:30 pm
Serge
Go to each of your pics. On each one right click and pick "properties". You will see an address URL. Highlight it and copy. Then come back here and type
[img]PASTE%20YOUR%20URL%20HERE[/img]
That's all there is to it. Do that for each one and then "post". Your pics should come up.
-Brian
PostPosted: Jun Sun 11, 2006 9:17 pm
Thanks guys, I'm learning. :lol:
PostPosted: Jun Tue 13, 2006 10:31 pm
Here are a few of my latest finds. Unfortunately the pics are on the temporary galleries (I use a Mac computer and can't seem to post here)
http://antiqueradios.com/gallery/view_a ... mName=temp
(edit by moderator - fixed Mac problem using a PC)
The pics are;
Zenith Royal 3000
Zephyr ZR-930 and Global GR-900
Black, handwired Royal 500
Beige/pink Global GR-711
Toshiba 7TP-30
A battery display from an old store
PostPosted: Jun Mon 26, 2006 4:11 am
here are a few novelty radios in a collection of over 1500 :shock:
www.noveltyradio.com/collect.html
PostPosted: Jun Mon 26, 2006 5:53 am
Jimmy Carter radios............... :shock: :lol: :D
-Brian
PostPosted: Jun Tue 27, 2006 11:17 pm
To satisfy my thirst for older and unusual multiband portables, I sometimes bottom feed on ebay when I notice a radio of interest is receiving few or no bids. This Philips L3X78T was begging for a bid shortly before the auction ended. While it has a ferrite loopstick antenna for the BC band, it uses a single flip-up rectangular loop for the 5 - 12 mhz shortwave band. Its handwired chassis is meticulously constructed and performance is very good for a radio that is stamped with a 7-Jan-1959 build date.
PostPosted: Jun Wed 28, 2006 4:55 pm
I've updated my collection post with the Sony ICF-5900W including a pic. I've also added an ergonomics post towards the bottom of the original post.
-Brian
PostPosted: Jul Sat 22, 2006 4:26 am
Here's half of mine:
http://www.tompolk.com/radios/radios.html
And now for something completely different:
http://www.tompolk.com/recorders/recorders.html
PostPosted: Jul Sat 22, 2006 6:06 am
WOW :shock: Very nice Tom.
-Brian
PostPosted: Oct Wed 04, 2006 8:59 pm
Here are some baby T/O wanna-be's that haven't left the nursery yet.
When Japan imposed an export quota limiting the number of AM transistor radios that could be shipped to the US, companies countered by selling these mini-multibanders which didn't have restrictions. Can you identify the one American-made set hiding among them?
PostPosted: Nov Sun 19, 2006 6:43 pm
Recent additions to the collection are a Panasonic RF-1600, a Panasonic RF-2200 and a Philips (model unknown).
The RF-1600 was a $10 purchase at this Fall's AWA flea market in Rochester. Although it's a little rough, it has taken up residence in my kitchen because of it's stainless steel look and good performance. It has continuous coverage in three bands from .530 to 18 mhz and from 87 to 174 mhz also in three bands. Audio performance is quite impressive.
The RF-2200 was an ebay purchase during a weak moment. It is in "like new" condition and lives up to the fine performance that others have claimed.
The Philips was a recent purchase from an ARF member who advertised it in the Classified section for $15. It came complete but in pieces. It cleaned up well and works great. It covers LW, BC, SW (49 - 19 meters) and (US) FM. The FM dial is on top.
PostPosted: Nov Sun 19, 2006 7:05 pm
Dave, that looks like my Norelco L5W34T. Yours might be the same except it has the Philips name plate. Look at my pic above. Nice performer BTW.
-Brian
PostPosted: Nov Sun 19, 2006 7:18 pm
Sure looks the same. There are two paper labels (one on the battery cover and the other inside the radio) that had the model number but they are unreadable.
What is the green light for? It flashes on briefly when I push the dial light button. Dial lights stay when the button is held down but the green light immediately goes out.
PostPosted: Nov Mon 20, 2006 6:44 am
Not sure? Mine does that.
-Brian
PostPosted: Jan Sat 27, 2007 9:48 pm
Heres some of mine.
http://akps58.wix.com/zenith-transoceanic-heaven
Last edited by Zenithman2003 on Aug Sun 10, 2008 11:21 pm, edited 1 time in total.
PostPosted: Jan Sat 27, 2007 11:38 pm
Art,
Very nice, high quality collection! You display your sets on your website magnificently. Do you have any other transistor radios besides the three T/O's?
Post New Topic Post Reply  [ 519 posts ]  Moderator: Dave Doughty Go to page 1, 2, 3, 4, 5 ... 26  Next
Users browsing this forum: Google [Bot] and 1 guest
