It is currently Jul Mon 26, 2021 11:52 pm
 Post subject: Permakay filter
PostPosted: Feb Thu 21, 2008 3:06 pm
Does anyone have an old Motorola schematic with this filter? As used in 1959 cab radios?
PostPosted: Feb Thu 21, 2008 3:18 pm
Hi Carl,
What information do you need?
These were sealed units. They provided the high-selectivity filtering for the receiver IF.
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Feb Thu 21, 2008 4:03 pm
Since I have several of these and they are 455 Kc, could they have a use in AM radios. FM then was I think about 5Kc wide.
PostPosted: Feb Thu 21, 2008 7:09 pm
Hi Carl,
No, these were never used in consumer products. I suppose you could install one in an AM radio if you wanted. The Permakay was a very expensive item, probably several times the cost of a complete AM radio.
I expect you have some of the pulls that were available by the thousands when the FCC dropped the deviation from ±15 kc to ±5 kc for commercial two-way FM radios.
This was a real simple change... one plug-in RCA connector, one solder connection, and four screws. There might have been one capacitor change also. It's been 50 years since I did one of those conversions. :roll:
73 de W3NLB
PostPosted: Feb Thu 21, 2008 9:57 pm
I would forget about trying to use one of these as a filter on an AM radio. The filter bandwidth on the earliest Permakays is around 36 KHz and 25 on the newer ones, and the skirts are not steep. The bandwidth of the filter is not the FM deviation, it is the channel spacing and then some. In other words, they are far too wide to be of any use.
The majority of Permakays are well sealed and potted in resin so you can't do much with them. However, there were a couple of early models which were marginally potted and they can be safely taken apart. There was an article in Hints and Kinks in the early 1960's on how to modify one for an AM filter, but the effort was large and I still don't think it's worth the trouble when you can buy a nice ceramic Toko filter from Digi-Key for a few Dollars. The insertion loss of the Permakay is quite high as well. Some versions have a solid state amplifier inside, halfway through the signal chain, to compensate (e.g. Motrac TFN6017.)
There was actually a Permakay made for AM, and used in Motorola's aircraft radios in the early 1960's. But they are very rare and I would still pick the Toko.
PostPosted: Feb Fri 22, 2008 3:29 am
With R-390A IF assemblies being readily available Im using the 8 kC mechanical filter for AM in a couple of modified BA's.
If you buy one of those assemblies be sure to get a guarantee that the coupling cap hasnt leaked and blown out the filters.
 Post subject: Re: Permakay filter
PostPosted: Sep Mon 21, 2020 5:47 pm
For all of you that have wound up here looking for the schematic of a Permakay filter, the US Patent 2738466 by B. Neiderman issued April 13, 1950, shows two 15 element filter schematics that are possible. It also describes why Permakays are almost impossible to disassemble short of using a hot sulfuric acid spray to depot them.
I remember them mostly in Motorola Twin-V's and Motrac's. Because the bandwidth changed with limiting and signal level, an unmodulated carrier could open the noise squelch before there was enough signal for voice.
PostPosted: Sep Tue 29, 2020 5:23 pm
From 1989 - 1991 I was replacing them in Mocom 70 Lowband mobiles. Motorola had a lifetime warranty and was still honoring it!
Tony
PostPosted: Sep Tue 29, 2020 6:31 pm
Early ones were over 30kHz wide. Narrow band FM +/-5kHz required an at least 13kHz BW. So, the later narrow band ones would be fine for AM BCB with some decent fidelity. But, as I recall they were rather lossy devices.
Post New Topic Post Reply  [ 9 posts ]  Moderator: Sandy
